Good afternoon. I have a problem with my raptor 700, bike was failing, many raters and I wasn't with good accelerator response but once in a while it was good without failing until it failed again it went down and never caught. however I did the test there is fuel pump pressure, the manufacturer recommends 324kpa and mine is doing a maximum of 230kpa and it doesn't catch, what do you think? thank you waiting for a reply
Yes, you need a new fuel pump according to the fuel pressure guage.
It is not uncommon for them to fail.
I changed the sail and the bike worked and the pressure went to 300kpa. the point is that I had already changed the spark plug once because the bike was faulty and the spark plug broke again. Why are you ruining the candle? Can anyone help?
You’re breaking spark plugs?
As velas estavam a ficar pretas e a mota acabava por começar a falhar, entretanto fiz o teste ao tps com o multimetro e está ok, afinei com o multimetro na posição de relantim para a voltagem recomendava pelo manual serviço e troquei o injector, em princípio já não falha e a vela está com óptima cor.
