1 1/2 turns out from the fully seated position is the stock setting. Fine tuning may be needed but that should be very close if everything is stock.
ive been told on several occasions that 3 turns out is the stock setting
1.5 is the normal, stock setting as delivered, but tweaking is required as all engines/carbs are different... and Yammi had them set too lean, stock, in order to meet emissions requirements.
