I havent ridden my quad in about 2 months and was thinking about using fuel stabilizer so that the gas doesnt break down and gum up the tank and carbs etc. I was wondering if I had to drain the tank before I cranked her up again and if anyone else has done something similar :3question:
I use sta-bil, and no you don't have to drain the tank before running it again.
Don't forget to put your battery in a climate controlled location with a battery tender.
so i just run the bike like usual with the stabilizer in it and then put new gas in when I run out?
Yep, I've always done it with my other engines. Just make sure you're putting in the recommended amount per gallon.
