The Raptor 700 is getting a fully programmable fuel control. If possible, I would like to get Owner’s and Tuner’s feedback before the product is finalized.
How many people want to mess with fully programmable fuel control versus just selecting already tuned Profiles for different engine, exhaust, airbox and fuel combinations? How many of you want to weld in (or have welded in) bungs for Ox sensors? Would you like to order exhaust pipes with an optional oxygen sensor bung already installed? What would this feature be worth to you (so the exhaust manufacturers can determine if it is worth their time to do it)? What is your priority for features like?-
Data logging for every second your Raptor has run
Programmable fuel
Programmable ignition
Ability to change-
Profiles (maps and all) on the bike without a PC
injector
fuel pressure
Extra features like-
extra pressure sensor for boosted applications (turbo, super)
electronic boost control
nitr. sol. drivers
I know what I want but that is not necessarily what you guys need....
Here is what is coming-
Direct replacement for stock ECU - Zero splicing into your harness.........
Fully programmable
Fuel
Ignition
At least 15 rider selectable Profiles. Profiles have everything from Maps and Timing to warmup enrichment and accelerator pump affect.
Mapping done by Volumetric Efficiency Table and Target Lambda Table
VE describes how your engine pumps and Target Lambda describes how rich or lean you want it to run at any point.
On board Bosch LSU4 wide band Lambda
At least 60 hours of logging and probably over 100 hours, all at 10 samples per second. There is no start or stop logging condition. All the data is stored since you first plugged it in and switched on the key. I do not know about you, but I am sick and tired of trying to track down intermittent problems without data.
Now for my real pet peeve and the reason I did this. Lambda is qualified as valid then sorted for each load point. The samples are then averaged and compared to your Target Lambda and you are presented with the result. If you choose, you can ask the program to fix your VE table to correct for rich or lean conditions on a cell by cell basis or globally for the whole map. I have spent way too many hours pouring over logged data from my megabuck data acq system to try figure out where I am rich or lean and by how much. PCs do this much faster and better than I can by hand. In addition, when you have the Lambda, logger and fuel control integrated, you can use engine status to qualify Lambda. In other words, if the engine is in warm-up mode, acceleration enrichment or deceleration enleanment, you just plain do not use the Lambda samples.
As for auto tune, I have never trusted a machine to make my tuning decisions even if its "authority" is limited. I would not expect you to either and thus it will not autotune. You look at the data for your machine and you decide what you want to do.
With respect to moving forward, the system is being finalized. Questions like how far from Target Lambda is acceptable? How many Profiles do you want on the Raptor?
All these things are being tweaked as we speak and thus I am very interested in people's thoughts and comments both positive and negative."
Programmable fuel
Ability to change-
injector
fuel pressure
nitr. sol. drivers
Fully programmable
Fuel
Ignition
