I recently bent my stock axle, and purchased a Gforce axle. I went to install it this afternoon and everything fits fine except for the rear brake hub. It is not wide enought to slide down to the carrier. All the stock original parts are supposed to work fine. The hub isnt large enough, and it narrows out towards the outside. Has anyone else had this problem? Is there a certain hub i can buy to fix this problem.
I have the axle in correctly.
Checked numbers it is for a 660
