Any idea what the part number is for the Cometic clutch cover gasket for a 2015+ and where to get them?OEM/Factory for the top end.
OEM or Cometic for the clutch cover(so it seals well around the check valve for the oil)
Most any other brand for the bottom end, from somewhere reputable like MotoSport or Partzilla, and use Yamabond or equivalent on the case halves.
That's the CometicMy suggestion for the clutch cover gasket is to reach out to Daniel at Cuervo racing and get the re-useable gasket. Then when you do the clutch again you can reuse the gasket.
Lol, no drinking that time. I honestly didn’t know it was the Cometic gasket. I just remembered having issues with my OEM sealing right and then getting the one from Daniel and really liked it. Zero issues with sealing correctly.That's the Cometic
You've been drinkin again, haven't ya
lol
Is it the 3 layered metal gasket that you have?Lol, no drinking that time. I honestly didn’t know it was the Cometic gasket. I just remembered having issues with my OEM sealing right and then getting the one from Daniel and really liked it. Zero issues with sealing correctly.
That's a different style then.I don’t recall it being like that. It was kind of a rubbery one I thought. That was a few years ago though, mind does slip like a burnt clutch in that amount of time now, so don’t hold me to it.
It's probably the same one.Then it could have been Cometic. Thinking harder about this, it was metal with rubber coating on it. Either way, it was a win.
