usually when i shift from 3to4 or 4to5th gear it will stay in the lower gear for a second or 2 after i let out the clutch...can any one help...is it a clutch adjustment or a big problem
Thanks, Matt
i dont think im half shifting it shifts fine some times but other times ill shift and the rmps will stay high, im guessing its staying in the lower gear and then it will smoothly shift up...it sounds like a normal smooth shift just a second late...its not grinding through its like a smooth transistion(the only way i can think of describing it) ill try and get a sound clip on of me switching
