I am going to order a set of ITP C-series wheels.... what size of rims should i order for the rear and front..... the factory rears are 9's i think, should i go with 10's ? ? ... I mean, should i go with the same size as the factory rims so i can interchange tires if i want ? ?
just let me know which rims you all think i should get.... thanks
Plattner
stock size and stock off set I would recommend If you change the off set wider you risk the chance of bump steer most peeps decreases the off set to narrow up the from end because of wider A-Arms
as far as the size 10 in the rear . If you need less flex in the rear then go with the 10
but these 6 ply tires these days are not flexing much on the 9" wheels ..
good luck with your purchase
Have you considered hyper rims at all? They do cost more, but they hold up better than the aluminum wheels. If they do break you can just buy the wheel half you need. It will also get you a set of beadlocks real nice for the terrain we have around here. Just throwing it out there for ya.
