i just took a small night ride and i happened to look down at my header and it was glowing red, is this a big issue and how should i fix it? thanks :D
If you engine temp is ok you should be good. Make sure there is not a rats nest in your exhaust pipe. I know it sounds funny but it took a buddy of mine 2 months to figure it out on grizzly.
Pretty common - you can open your fuel screws up another 1/4 to 1/2 turn and you'll likely see the header dim out a lot. As long as idle and coming hard onto throttle isn't affected, you can stay here on the screws.
its running real good so il just leave as is but thanks for the responses!
