1 - 15 of 15 Posts
can somebody post a link to a decent grease gun that wont cost me a shittload of cash and will be user friendly and i can use it on the rap!!! thanks im not all that mechanicLLY inclined so iam "learning" how to care for the bike THANKS
I use a standard size grease gun with a rubber hose and have no problems getting around the 700.
I use the standard type with a flex hose as well. I have the one that will take tubes or you can fill it from a bulk container by using the pull handle on the end for suction. Point about loosening end is a good one. Sometimes the fitting goes on good, but is a bitch to remove. Loosening the outer part of the fitting when it's stuck will usually rectify. The fitting is somewhat similar to the way a drill chuck works. A threaded piece on the end tightens against the clamps inside to fit on the grease nipples.
MK
ok i got some lithium grease multi purpose from pep boys is that ok to use or do i need lithium soap based specific grease??
It's the same thing.
i use a lithium complex grease, also it is hi pressure water proof and high tack, but probable no diff from the multi purp. grease..
I just snaped a grease nipple... again. What am I doing wrong. It goes on fine but then it wont come off. I've never had a problem like this with any of my other vehicles.
size12 said:
Just an idea but i put 90 degree Zerks/ grease nipples on my A arms made it a lot easyer to grease her up :thumbsup:
I did this on my 660, makes using the grease gun a LOT easier. Especially my grease gun since I dont have the flexible end, its solid.
1 - 15 of 15 Posts
