What size "zerck" fitting grease gun do I need, and what type of grease should I use?
Grease guns are standard im pretty sure, im never really seen different sizes, and you can use any grease (not cheap shit) the white is good and we use the red in my dads tractor trailer.
Once you put it on the nipple you can tighten the fitting on the gun to the nipple.
I just went thru this...I would pump the gun and grease would go everywhere except thru the nipple. My gun was old and I didn't know that you could adjust the end so I went to a local car parts place and bought a new end for the gun ($ 5 cdn) that was easily turnable to adjust it to the nipples.
FYI the nipples are a 5mm
