How do you glue grips on, its hard enough without a lube, does the glue act like a lube and where do you put it, inside the grip or on the handle bar???
Glue does act like a lube, put the glue on the bars and spread it around a bit , then push the grip on an twist it at the same time...do quickly before the glue sets up.
I use the ODI locking grips , they are great. No glue,etc. And they do not budge. They cost me $19. Standard grips are usually 10-15 bucks , so $19 for the locking style is not bad.
man i wouldn't even use glue if i were you. get some ether or some hair spray, spray it inside the grip then put it on the handle bars. you will never have a problem with them after that.
