Hi guys , today just got some hand warmers because here in canada its starting to get pretty cold but i would want to know where to wire my hot wire on the atv i would like to have curent on it only when the key is turn on.
thanks Guntox
#327 "After Hours"
Wire it into the hotside of the ignition after the key is on the "On" position
Directly on the wire in the key ignition ? Will that circuit be strong enough ?
#327 "After Hours"
You'll have to check the amps on it. Hand warmers aren't that much, just compare your results to it to what you have for the warmers.
The UK's fastest Raptor
you could wire it directly to the battery and use a relay energised by the ignition. No worries about power consumption then.
finally I installed them on my front light circut and everything works fine when the key on off the stop too. And damn do does things work good when they were on hi I tought my hands were going to burn lol
