i have an 05 350 and when its running its hard to shift into neutral, any suggestions how to fix this or make it easier? it skips right over neutral straight to second or vice versa if you go from 2nd down
Could be a few different things. Is your linkage worn? Are the splines on the shifter good? How does it feel into other gears?
mine has the same problem. I hear a direct shifter helps. I adjusted my shifter a bit and it sort of helped also works better when it is not so cold. Is a pain in the A$$ especially when someone else is riding.
I have a direct shifter. It helps, but I think the little black thing on the end is kinda short.
