I am thinking of trying them at a different level any suggestions. They are now set at 80 20 20.
Seems like most run at those same settings. That's what mine is set at, only because that was the advice given here. What do the 3 numbers indicate (I forgot)? Maybe I'll start playing around with it, too.
I run mine at 75,10,10. 80,20,20 seamed to be adding to much fuel causing a slight bog.
Yeah I think 70 15 15 feels better on my quad, I was getting a slight bog off the line as well with the other settings (80 20 20, and 90 15 15).
No it doesn't take away fuel only adds. I talked with Jamie at Fuelmoto. Experiment all you want with this feature is basically what he said. Now if you are already running lean this does not fix your map though. Good luck. I found that the lower I went on the sensitivity, the first number, the more it tended to bog - too much fuel.
