Hey what are all you guys gapping your valves at for the 5050 cam? I was told it was .005" intake .006" exaust. But I just talked to another guy who is gapping them higher. Is the valve lash build specific?
Hmmm... Dl told me .005 .006 WTF!! I wonder if thats why my bike is a cold blooded bitch
But the web 4 isn't exactly the same as the HDD is it? Something must be different like duration or lift etc. Didn't you run the 5050 in your rappy wobble?
And is the valve lash adjusted differently based on build design like larger valves or HC piston, BB etc.???
I'm nats ass .005" intake .006" exaust right now and it runs rough as hell up until it's about 180 degrees then coughs it all out and runs great except the idle fluctuates a bit.
Yes carpenter. I ran the 5050 before I had the Web 4. I used .005/.006 (DL's recommendation) on the 5050 and .006/.006 on the Web 4. Both builds ran great.
They have same lift, just slightly different duration.
Gosh I cant remember the values of hand. I checked them though and confirmed with DL that they were correct for high and low. .6 something low and 3.5 something for high approx. It's like the cold idle is all funked up. I should bring it down and monkey around with it with you?
