1 - 12 of 12 Posts
~~~ 660 Specialist ~~~
How much would it cost to send u my head and have u p&p it, valve job, clean up, and all the stuff that goes along.
Also where is the best place to get a Hotrods 720 crank and piston from?
thanks
I ride mostly trails and a little of track and sand, if that helps
Discussion Starter #2
ttt, but changed my mind a little, what would be the charge for a p&p, valve job, and stuff that will go along. Im now goin with a 11:1 101mm Weisco piston and maybe a stage 2 cam, but do u also do the rocker grinding or do u have to?
Discussion Starter #5
so 400 all together? Now will that work with the stage 2 cam and 101mm piston? Thanks for the help, and it will take a couple weeks but I will for sure be sending u my head sometime, just gotta get the funds together.
Yes, the trail port works great with that setup, the stage 2 hotcam is very hard to beat for recreational use, recommend you have the valve guides shortened while its being ported to allw you to drop in any shelf cam.
Discussion Starter #7
Got a couple more ?s, do u do boring, cause it would probably be easier to just send u the cyclinder too. With the head do I need to get the KW Springs, or is that something u carry? Also should I get better valves, and if so what brand?
1 more, do u sell hotcams too?
Just trying to get a total cost of everything so I can get it done all at 1 time.
Thanks
Mike has everything you need, he's a one stop shop and he'll look after you good!!
Discussion Starter #9
ttt, just wondering a final price for everything done to the head. P&P, Valve job, etc.
Also if u could add in the price of whatever mods for the stage 2 cam, and the springs that u need for it. Thank you, I know im probably bugging u.
Hi Mike,
I wish you would have put the price on the thread instead of a PM. I am looking to do everything just like RampageRaptor03 did but would like to know the final price.
Thanks!
Hi Mike,
Thanks!
Please PM me exactly what you want and I'll be happy to give you a price quote.
1 - 12 of 12 Posts
