Which wire is for the low beams and which one is for the high beams? Also is one side For High beam and the other for low beam? Mine was working on the right side for low beam and the left side I think for the high beam. But both were never on at the same time. So confused, can any one give me an answer on to why?
Yellow is high, Green is low.
Welcome to the forum!
Discussion Starter #3
Okay that helps! But what side is high beam and low Beam, Right side or left? Or are both sides high and low? Every time I used mine only on side would work for low beam and the other side was high beam.
Both sides for both... each bulb has two filaments.
