1 - 2 of 2 Posts
I just bought a used raptor 660r I put a new starter in it and relay but it still has a hard time starting how do u adjust the timing adjustment without taking bike apart thank you
Have you Checked your battery voltage?
The timing is set by a chain. You can not “adjust it”. It is either timed correctly or it is not.
The only possibility is that your chain could be stretched beyond reason and causing timing issues. So check your tensioner first, if anything.
1 - 2 of 2 Posts
