1 - 12 of 12 Posts
I'm looking to the easiest and most gaining mod after the big 3. What is a good mod or two after the big three? I'm thinking cam maybe?? Help, advice needed. Thanks.
Banned
A better exhaust and intake will give you more power, depends on what hp you want to achieve, how you ride, where you ride, besides that suspension should always be on on your list, good suspension make you faster and more comfortable
i ride trail and sand so i could use suspension but
i would think price wise a cam. duals cost a lot.
If you can only do one mod right now, get a HC2. It has shorter intake duration and will help retain cylinder pressure with the oem 9.2:1 (lame) piston.
If you can do two mods I'd recommend the TQS 11.5 piston. If your more a trail guy in the woods I'd run the HC2. If your a open area dune guy, the HC3 will give a few more hp but only at the very top end.
After these mods, you should really open up the intake some and get a +3 TB.
Hope that helps.
Hope that helps.
+1 :thumbsup: a better exhaust and intake will help too. suspension is something that needs done also, but it sucks cause its so expensive to do it right. :mad:
I was thinking cam too. Didn't think my exhaust and intake were that bad.
A cam and a high comp piston will make a big improvement.
1 - 12 of 12 Posts
