The temperature meter is OK (I think), and the rev meter is very inconstant at idle, but that seems to be a common problem...
HOWEVER, my biggest problem now is that the speedometer is not working properly!
Sometimes is stays at ZERO km/h when riding, other times the speed is too low! The speedometer is accurate less than 50% of the time!
My guess is that the wheel sensor is not sensing all the wheel revolutions. That would explain the low speed on the display (or zero speed). If it does not detect all the revolutions, it probably thinks that I am going slower.
What could be wrong? Any suggestions? Is there anything I can check on the installation?
Thank you for all your help!
