So i took my carb off to clean it and the airbox, filter..etc.. cleaned it with gas and let it dry for a day...then put it all back together connected everything correctly..then started the quad...let it run for about 1 minute...then turned it off, i noticed there was fuel leaking from the carb area?...what is this?
my dad says i might have bent the float tab while cleaning it so its overflowing thru the air boot? or could ot be something else? Im not sure....Help please!!
(NOW I have to go take it all apart again,,,.hhuhhmm yay!!) :/
YOur dad may be correct..........
OR you may have dirt in the needle and seat, OR you may have incorrectly adjusted the float heght, OR you may have a worn needle and seat...............
Discussion Starter #3
Ya i think i found out the prob idk yet :)
its a worn seat gabe mine had the same prob:D
or the gasket like you told me
Discussion Starter #5
Well ill see im gonna replace the Bowl seal tonight and see if thats the prob if not then i might replace the jet idk ? hopefully it will be ready for reno :)
make sure you get it fixed cus i dont want to have to tow you back lol;)
Discussion Starter #7
Ya well it will run its just gonna leak fuel! :p
