1 - 9 of 9 Posts
Changed my oil last week and this was my first good run since. I checked the oil level after the bike cooled down and the level was almost a quarter inch over the fill line. How can bad this hurt my engine? What should I do? Drain a little, or completely re-change my oil? Since this was the only hard run yet will it be okay?
Re: how bad can it hurt the if......?
I would drain a little. I once rode almost all day duning at about a half quart over before i checked. scared the crap out of me but didn't seem to hurt anything, that was over a year ago :thumbsup:
Thx, I hear ya about being scared. I don't need another expense to fix it right now. Not to mention the down time.
Your quad should be fine, but I would drain a little. If it reads 1/4" high when it's cold. If you run with too much oil it could cause a leak.
The Raptor has a dry sump oiling system. Oil changes have confused a lot of people. When you do an oil change drain the tank, and the crankcase.
Add two quarts. Nothing more and nothing less. When checking the oil make sure the quad has sat unfired for at least 10 minutes.
Follow the manual and you will do fine. Some prefer to add one quart to the oil tank and one to the crankcase. This is fine too.
Yeah I drained both and changed the filter and put 2 quarts in still ended up 1/4 inch high. Hmmm.... What could I have done wrong?
Possibly the old stuff didnt drain completely?
Make sure you run it long enough to completely heat the oil before draining it. If you live in a cold climate, it won't all drain out if left cold.
1 - 9 of 9 Posts
