1 - 17 of 17 Posts
Can someone identify these 2? What do they do and can they be the culprit to my rappy not starting?
The plugs are in the background
Parking break and clutch switches I think. Does it start in Neutral? Does the dash light up "N" when it's in Neutral?
mine doesn't have those plugs anywhere on the bike. they must be for the kill switch, park brake, clutch switch or similar as mine has everything bypassed and removed.
EDIT. hang on, i have a clymer manual i can look at real quick and post a pic.
if it is the yellow/black & black bullet connectors, its the clutch switch.
the green/yellow & black in the white connector is the park switch.
off topic, was the red wire on the coil replaced? mine is yellow or orange and thats how it shows in the diagram in the book. maybe that wire was cut n spliced somewhere and its not getting spark as to why its not starting?
The one with the white is the parking break sensor. It engages a rev limiter when the parking break is on. You can just unplug it. Wrap a little black tape over the end of the plug to keep water and dirt out.
The two bullet connecters are for the clutch lever. Unplug the sensor then plug the two bullet connectors in to each other to by pass the clutch safety start switch.
Discussion Starter #6
It does not start, N is light up before i crank it.
Mine is orange it just looks red in the pic, I tested the coil and its giving out a spark.
I will try that later today, hopefully itll work. Thanks
Discussion Starter #10
Sounds like the oneway clutch is slipping when starting......
I have one that came w. The package, do I need the special key to remove it or is there another way I can get it off? Also does it matter if it has a few small dents on the new starter clutch? The guy I bought it from doesn't look like he used the tool to remove it.
Show some pictures of what you are talking about.........
Discussion Starter #12
I will once im at the garage tomorrow, BUT i will mention that i took off the air filter and sprayed starter fluid and the same thing was going on.. could it possibly be the carb?
Have you checked for spark?
Sounds to me, also, as if the starter one-way is slipping occasionally.
Discussion Starter #16 (Edited)
yes im getting spark, and im pretty sure you guys are right. the one way starter spins freely both ways then locks up and spins one way and then frees up and spins both directions.
UPDATE: didnt want to bump old thread.
Replaced oneway clutch and started right up! thanks guys!
If ya need a manual check my sig and send me an email.
1 - 17 of 17 Posts
