1 - 15 of 15 Posts
i was hoping someone could help me identify some of my aftermarket parts. i know i have a durablue eliminator.
Looks like wider axle, 12 tooth front, not sure but it is an aftermarket rear sprocket, wider a-arms, aftermarket front shocks, gytr heel guards, nerf guards, aluminum skidplate, subframe is square so it is off an 01 so your rear shock is does not match the subframe, since the frame is blue it must be an 01, so your rear shock is off a later year, and it has a hotcam sticker, so possibly has a cam...
just noticed your signature... disregard half of what I said lol
You have a stock swingarm on there, I know at one point you were wondering if it was longer or aftermarket. Stocker. A-arms are going to be tough to tell the brand, the picture quality isn't the greatest. Cell phone pic?
Ya. And it looks like my swing arm has plates welded on it. Stock or did somebody modify it
Where does it look like there are plates welded on it?
There on the inside next to the shock both sides. From about halfway to the axle
looks like a stock swingarm to me, they used to sell an extended kit like this...
Yeah he has a stock swingarm, and there is no JTM swingarm extension on there, I've got one on my bike, and his doesn't have it.
HOw can I tell what shocks I have
1st pic suggests your chain is too loose.
Axle bearings are shot. Ganna replace em on of these days. And no I don't ride it with em bad. Haven't had them time to ride so I haven't been real worried about replacing em. Plus I gatta work on my wrangler do it'll be even longer
Wiesco 11:1 piston 101 mm bore, and a Stage 1 Hot Cam
What? Random
1 - 15 of 15 Posts
