1 - 2 of 2 Posts
this coming weekend they are having a classed radar run at the local frozen lake
i will be running in the stock non studded class
can someone post a pic of the connector i'd disconnect to get rid of the 5th gear revl imit for the run?
also i was thinking of lowering rear tire psi to 3 and raising fronts to 6 so the front will roll easy and the rears have the largest footprint possible on the ice....
any other hints are apprecianted
lastly as i do in dragracing cars, i was gonna hit the kill switch as the finish and pull the plug
if it doesn't look like its on the lean side i will make another run with the lid off
i want to make a good showing,as in fast speed and not blowing it up... :thumbsup:
thanks in advance
-dan
1 - 2 of 2 Posts
