Pick 2, Im getting them in 22x11x9
  • ITP XCT $160
    Votes: 0 0.0%
  • Maxxis Razr2 $170
    Votes: 0 0.0%
  • maxxis All Trac $114
    Votes: 0 0.0%
  • kenda knarly $104
    Votes: 0 0.0%
  • knarly xc $114
    Votes: 0 0.0%
  • klaw xc $100 (out of stock)
    Votes: 0 0.0%
  • Mud Lite $124
    Votes: 0 0.0%
  • super grip $110 (mud lite, look alike)
    Votes: 0 0.0%
  • Trac stars $146 (out of stock)
    Votes: 0 0.0%
  • 21" GNCC $164
    Votes: 0 0.0%
  • Other, please post and why and post price
    Votes: 0 0.0%
1 - 20 of 20 Posts
Ok, you guys helped me with the paddles now help with the dirt tires
I already have some 23" razr fronts now I need 22" rears, Yes I need bigger tires, I need the ground clearence, its sucks getting suck in a mud hole or on a rock
tire name and price
and most are from rocky mtn, I get 10% off also
Discussion Starter · #2 ·
I added a few more from a somewhere else
You can Vote for 2 options, also you can change your vote
If I missed any good options let me know, i will add them
I selected Razr2's only becuase they are the only tyre i have gone with since the crap stockers..... But i have absolutley no complaints about them at all, i am very happy with them... Good luck :thumbsup:
i chose tyhe razr2 also as they are good for the price and a good overall dirt trail tire that takes more abuse then the stocks. also they have way more bite. i think they would also do fairly well in light snow and packed sand. :3question: my raz2 just got here today from rocky mountain..
I compared the i-razr, razor2, and the gncc at a shop in phoenix. I ultimately chose the gncc (21" rears) after speaking with the other customers and staff.
Don't forget about wheels!! We have another set mounted on stockers, went from Prescott to Lake Pleasant (here in Az) which is a rough trail. He nailed a rock at speed sliding around a corner, pinched the gncc on the rim, bent the rim up about three inches! The tire has a tear in the sidewall and by the bead, and the only leak is at the bead. Put the tire on a new rim (bajas with reinforcement rings) and it's ready to go again. Awesome tires. Oh, and he's running 20" rears.
DJ
Haven't heard much good about the trac stars. Long and short of it is they don't hook up or clean out well. If you're on hardpack and don't mind spinning a little you're golden. I will include the disclaimer that I have not personally ridden on them, but the sentiment I am forwarding is that of someone who has done his own testing and has legitimate knowledge of the subject.
If you're talking about mud holes and rocks I'd make sure it was a bias ply type with 6 plys. I'd go with the XCT if you're focusing on clearance on harder pack, but with the terrain you're describing I'd op for the RAZR 2 if you've got the cash lying around, knarly if you'd prefer not to spend it. Personally my next set will probably be either xct or knarly 22" rears with a front ytbd but my mud riding is very limited.
Discussion Starter · #14 ·
Every thing Ive read is that the lug depth on the reg. razr is less then the 2s, I have a friend with razr's on a blaster, and there decent
I have the XCT's on the rear. they have about 40 hours of use. I rode for 30 miles on pavement and then started to wear they most there but still have more then off there tread left. I rode them in woods,desert,mud,silt, anything you can thing of out on th trail and still have plenty of life left. Got them for $120 at my local dealer.
Carlise Badlands I run 23's up front,22's in the rear.Where I ride I need the ground clearance.I have run them in the rocks,snow,sand.Have run them on a warrior,45hp Lt250r,and now my 07 Raptor.Luv'em.Hope that help! :)
1 - 20 of 20 Posts
