But should I be running toe in or toe out? LIMITED660 suggests to run 1/8" wider in front than the rear. This would make it toe-out, correct? I just want to make sure we're on the same page.pewterpecker said:The front (bumper end) of the tires should be closer together than the back (exhaust end) of the tires for toe in.
And for camber, the tires should be closer on top than bottom. / \ not \ /
What he said, TOE IN, narrower in the frontpewterpecker said:What?
No you want toe IN. That means the front of your tires are closer together than the backs.
