help.........need a quick answer
ok i was riding the other day and my chain popped off and slid down on the inside of my front sprocket. it shredded the chain roller and the ring that is behind the sprocket. need to know what that ring is called so i can order it asap. if you take the front sprocket off and the lock ring there is another ring behind there that has a 10mm bolt at the top which is the one that is messed up
Re: help.........need a quick answer
i dunno what its called exactly but i have an extra if youd like to purchase it and ill ship it to you. if not you should be able to get it at your local stealership. and you could get the name of it in the repair manual located in this thread http://www.raptorforum.com/index.php?topic=4.0
Discussion Starter #4
i would get it from you but i need it by tomorrow so i'll be making a trip to the dealer tomorrow. also if this bent would all the oil leak out or do i have a more serious problem. didnt get a chance to really check it out due to lack of daylight.
if its leaking oil then the o rings in there are bad. there are 2 o rings behind that. look in the manual in the thread i posted and it will show you where they are and what to take off to replace them. they arent hard and it doesnt take long at all
