1 - 2 of 2 Posts
help needed...tires keep going flat
my tires keep going flat. if i fill them up above 7+ psi then they stay inflated. the problem is that when i put < 7psi, like 4.5 which is the recommended for dune riding they loose air quickly. need suggestions
get a bucket of soapy water and a sponge....fill the tires up with air and sponge the soapy water onto the tires...you will see huge bubble where it is leaking...I'm assuming its around the bead and the increased tire pressure is holding the bead on a bit tighter....but don't forget to put some soap on the valve stem also
1 - 2 of 2 Posts
