Help no spark
119 Views 4 Replies 3 Participants Last post by  QuadManiac
I have no spark in my 2003 660 I’ve changed the stater and and the coil and still no spark checked the orange wire to the coil and it is grounded I check to see if there is ac volt going and it has none, I check the kill switch and tried a new one and seems to be fine I think it’s the cdi but brake lights and neutral and temp are working it turns over just no spark what else could it be
if you bought a cheap ebay stator thats probably the problem. need to stay with oem or rickstator for that particular part.
We checked the stator and everything checks out
those aftermarket ones will play with your heart.....
search the forum for stator issues, you'll see the fun they deal with........ 660's a beast but gotta put quality parts on it, it likes to break the cheap stuff pretty fast.
If the wiring has not been modified your symtoms point straight at stator or CDI... but CDIs seldom fail and new stators do fail often right out of the box.
See if you can borrow an 02+ CDI for a quick test - the only way to tell without buying one.
