went out yesterday raptor 660 05 run well then just cut out.checked plug no spark new plug same thing unpluged voltage regulator still no spark ideas please
I'm going to assume that the run/stop switch is at run, and the starter IS turning over when you press the start button, correct?
Check the orange wire's connection at the coil. Unplug and re-connect the connection between the stator and harness, and the connectors at the CDI (do this several times to remove any corrosion that may be on connector pins).
Git-R-Done
no spark
right tryed everthing now going for some new parts is it worth getting the complete stator or just the pick up coil if i read it right only the pickup coil has anything 2 do with the spark
If I remember right the pickup coil is part of the stator assembly & must be bought together...That is if I remember right..
