1 - 10 of 10 Posts
I have a 2003 Raptor..
I cleaned my Gas tank w/ the hose and made sure it was dry befor putting back on!
I cleaned my CARBS, I cleaned them with the throttle still atached... I just sprayed Carb cleaner in it, all around in the everypart. and then used air in a can to dry it and push away the dirt...
My brother did it so im unsure of how exactly he cleaned them, I dont think he took the jets out or the float.
We changed the spark plug too, It was pretty WET up in the place... and the other spark plug was soaked so we put another one in..
We connected, it all back together... and put fresh gas into it..
When we tryed to start it it doesnt kick in at all, just zzzz zzzz zzzzz it wont TURN ON, and sometimes a BIG BANG comes out of the exhaust... WTF is WRONG..
ITS DRIVING ME NUTS?
your one way is bad if you're hearing zzzz from your starter.....start saving cause they're a couple hundred bucks.
Max
Its not a ZZZZ its more like it wont turn over fully!
I asked you that the other night and you said it turned over fine. If it's just a buzzing sound charge up your battery. That should fix it.
is the starter turning but not the motor? or is te battery dead enough that it wont spin the engine over? did you do a valve job recently?
is it a zzzz, a zzzz zzzz zzzz, or just a zz zz......good grief, where's the sound coming from dude. It's probably your starter relay then because your battery's dead. Charge it and give it another shot.
Max
help yourself a bit here rundle, eliminate possiblities, then come talk to us.
Hey guys,
i heard a strange noise coming from my buddies raptor......do any of you know what it could be???.... ::)
1 - 10 of 10 Posts
