hi everyone im new on raptorforums.com can any one give me some insight on my problem? iv got a 06 rap7 and the cooling fan will not run ive done basic problem solvers on it and still no luck hot wired fan and it works checked relay and its good checked circut and circut plug and thats good so i checked the cooling wiring diagram and basicly found that the the nagative signal from the ecu that activates the cooling fan relay is not coming thru so when i ground that wire the fan will kick on and thats what i cant figure out and i checked the wire from ecu to relay and its all good and im not sure but i think the temp sensor is good because its turning on the overheating light on if any one can help me id greatly appreciate it im at the point ware i think my ecu is maybe the problem
