??? I bought this quad last spring. It is an 03 660. Im wanting to replace the Lower heim joints but no one knows where i can get any? Plus having trouble identifing what kind of a arm they are. I know the dude flat tracked it. Their are two positions that the shock can mout on the lower, and they are +2 ... other than that im lost. Any help would be appreciated:confused
Your probably going to have to take your old heim somewhere and match it up, try going to some local off road truck/ buggy places or you might call ASR they use heims on their a arms, maybe they have a match for it.
thanks
I got ahold of a ASR rep and he said hes 99% sure that their heims would fit .. just sucks cause they are the only ones i can find and are 120 bucks. Thanks for your reply
Look at McMaster Carr (mcmaster.com) for a large assortment of Heims at much lower prices (once there, search 'heim joint'). If you can measure yours, you should be able to match one up. What look like possible candidates start around $10.
I would figure out what thread they are and look for ball joints.
