1 - 20 of 21 Posts
so i received my set of monster duals and i am now trying to install it..
when i removed the stock exhaust i noticed that the stock was using a gasket.
do i have to use that back with the monsters? or is it ok to install without them?
^^thanx..
so i already intalled the exhaust but not yet the fci...
after about a min of stating the raptor i noticed that the head pipe was turning red hot and i immidiately shut it off, any suggestions? did i do something wrong?
you need to. without a fuel controller youll ruin your top end and your bike wont run at its best
I shoot fire out mine it's a damn flame thrower
You're good ride the ____ out of it lol.
red glowing headers are normal. just make sure you got your fuel programmer dialed in...
WELL SAID! just set up the fuel control and dial it in! The plug is right there so let it idle and check the plug! If its a nice light brown color then 1/3 of the battle is done.Then work on the mid and wide open.
1 - 20 of 21 Posts
