hey guys hoping to get some help, so a few weeks back my rear sprocket came off and the chain busted my reverse and neutral switch as well as the wire that leads to them. I installed both a new neutral and reverse switch but didn't think about the wire, once I had them installed I left the wire disconnected from the switches and now it doesn't want to go into reverse, i tried contacting the wire but its pretty damaged so I can't really secure it. Anyone know if the wires have to be connected in order to put it in reverse? Or is there something else wrong? Its a 2007 raptor 700 thanks!!!
There is something else wrong...
Reactions: 4stroker4life
Discussion Starter #5
Didn't notice any weird noises but its possible it broke some of the internal gears. It did break both the nuetral and reverse switch if thats what you mean, but I replaced both
Take the reverse cable loose, and try holding the lever, engaged, while going into reverse.
