1 - 2 of 2 Posts
Hey Fellas, i have a 06 Yamaha Raptor and changed the starter clutch and put back together go to fire it up and nothing! Click, click from the relay! Left it fustrated over night tried starting it after charging the battery and now not even a click! Purchased a new CDI and battery relay and still nothing. The green neutral light comes on the lights work and new battery? Any ideas? Appreciate your time! Thanks....
1-Charge the battery
2-Check the ground cable that clamps under the left side case cover bolt.
3-Check battery cables - are they clean and tight?
Welcome to the forum! Are you outside the US? '06 660's don't exist here.
1 - 2 of 2 Posts
