1 - 20 of 21 Posts
I know this sounds really dumb but my pro grip grips just wont stick. Ive tried w-d 40 Brake fluid and grip glue they just wont stick i think im going to try gorilla glue next if u have any suggestions please tell me.
try cleaning the grips with denatured alcohol and then try the grip glue
i was told to use spray paint, lubes it when it goes on and sticks it when it dries, it worked a treat for me
Ben
Ryans Roostin Raptor said:
I install mine the same as golf clubs.
do you use the golf club tape?
Step one:
Take your favorite spray paint color and lightly coat the inside of your grips
Step two:
slide your grips on
Step three:
If the slid on realy easy they sold you the wrong grips
Step four:
go back and get the right grips
hair spray works for me too :thumbsup:
snowman said:
Step one:
Step two:
slide your grips on
Step three:
Step four:
I think I agree with snowman...I think you might have the wrong diameter grips or maybe they were for dirtbike. :crazy:
I have Pro Grips on mine.
Make sure you clean off all of the original glue. I put mine on w/o glue and the left one kept walking off the handlebar (the pic is pre-glue and if you look close you can see it's all turned around the wrong way). I took it off, cleaned the original grip's glue off the handlebars, used Renthal grip glue when re-installing and it's stuck on there good.
I put a liberal amount of glue on the handle bar and twisted the grip front to back while it was going on. It's stuck on good now.
Now I kind of wish the right side would come loose so I can glue it - lol.
Shawn
Raptor_rpr said:
I use hair spray!! :thumbsup: never had a prob
+1 ... works great, lubes the grip, goes on transparent, dries fast. :thumbsup: :thumbsup: :thumbsup:
I had the same problem this weekend. I was doing a wheeling and all of a sudden my right side grip came off in my hand causing me to flip it. oops.. Figures, brand new plastics too.. Since I was in the middle of no where. I used one of those lighters that you light grills with.. I got the insides all warmed and gooey and slapped it on real fast, havnt had a problem yet. Other than that aqua net.. the hairspray works real well
I have put grips on jet skis and motorcycles, Aqua Net Hair Spray is the stuff to use...... :thumbsup:
Discussion Starter · #18 ·
ok thanks i think ill try the hair spray but i even tried this supossively really good glue yesterday and today i was ridin they were fine then i started ridin the wheelies and the outside of the grips started moving if it gets worse ill try the hairspray thanks again
Since you've had so many failures...
Make sure the old stuff is cleaned off good. Are the grips stretched out from coming off so much?
1 - 20 of 21 Posts
