1 - 20 of 23 Posts
i redone my crabs and trying to get the thing to start is the temp light should it be on all the time when you trying to start the atv and the thing well not start for some reason it run before i redone them now nothing turns over and got fire
To bad your clear up in the NE part.
Temp light should be on while start button is depressed.
WHat exactly did you do? Obviously, if it ran before and it doesn't now, something you did is at fault. Let's see if we can find it.
well it not run if i dont have the air fuel mix right i think that what they are called the screws that are on the outside of the crabs on the bottom
that is the only thing i know that i messed up on is that everything else put back what i take out the same way
Turn them gently in (CW) till they seat, then turn out 2 turns each - should be close to where you want them.
Did you remove and clean the individual jets, and did you get them back to their original positions? Some are different between the two carbs.
Also make sure the carbs are tight and fully mounted on the carb to intake manifold boots - any leak here will cause starting problems.
ok i did a DUMB ASS move when i put my rebuild kit in the crabs i didnt count nothing or put the jets or anything else is the right place does anyone know where i can get all this info to get it back to where i need it so i can have a running bike thanks
Bigger main jet on the right hand carb, pilots are the same size and are up a tube and the cold start jet is in the left carb.................:)
Download the manual - follow the link at top of the 660 maintenance section.
Discussion Starter · #16 ·
well guys thanks for the help download and did everything by book and what you guys said to too and still wont start so i guess ill give up and take it too someone that knows what they are doing i guess
So... what ARE your symptoms now?
still the same thing well not firer up it has spark it has fuel and still nothing
Does it tow start, does it start when you spray ether into the carbs............
You may have a stator problem, even if you have spark...............
how do i tell if the stator is no good no have not done the pull start i live in town and they dont like the atv going down the street lol
1 - 20 of 23 Posts
