i was wanting suggestions on a high compression piston. i was wanting to use a stage 1 hot cam and a standard stroke and bore high compression piston. i want to be able to run pump gas. how much of a compression bump could i use.
I was also wondering when you install a hot cam does it have to be degreed. and do you need the shim kit for the stage1. oh almost forgot i am running a 2005 660 with ct racing exhaust an pro design intake system with a k&n.. and also will there be a noticable power increase with this setup or should i just go straight to a 686 big bore kit. i am trying to build the most power i can on a tight budget.
