thinking of just do a cheap season this year and maybe a bit of cosmetic so a CP 11:1 and hot cam 3 for xtra grunt worth it
Of course! I'd go with the TQS 11.5:1 though for about the same price and still runs pumps gas. More bang for the buck! I did a 11:1 and HC2 and I'm very pleased with the difference.thinking of just do a cheap season this year and maybe a bit of cosmetic so a CP 11:1 and hot cam 3 for xtra grunt worth it
All signs point to yesim always beating the shit out of it and on the rev limiter so stage 3?
Yes sirim always beating the shit out of it and on the rev limiter so stage 3?
I dunno MD. I've always referred to the hotcams as baby cams as well. I don't think there is one with less lift than this one (not counting stock), but I could be wrong.I wouldn't call the HC3 a baby cam, and I agree you should find a lot of useable power with that setup if you like to rev it out.
How hard is it for you to get race gas or avgas? Lots of people want to push compression limits, while it only takes one batch of bad gas to end your motor.would anyone know answer about it?
its impossible highest octane gas I can put my hands on is 91 oct and mix it klotz octane booster to around 92 - 94 octHow hard is it for you to get race gas or avgas? Lots of people want to push compression limits, while it only takes one batch of bad gas to end your motor.
The HC3 is about as "big" of a cam as you can fit without clearancing the rocker arms. No it's not comparable to the megacycle x2 and 4 and web 290 or some of the builder cams but as you stated it's capable of really waking up the engine. Perhaps it's just my frame of reference, I don't have experience with .480 and .500 lift cams and I'd wager a lot of others don't either so we're comparing the HC3 to stock where the HC3 doesn't look like quite so tiny.I dunno MD. I've always referred to the hotcams as baby cams as well. I don't think there is one with less lift than this one (not counting stock), but I could be wrong.
Although the title says high comp and I wouldn't consider 11:1 high comp. :lol:
Max9string, as others have stated, this is a very common and proven combo. You'll be pleasantly surprised how much it'll wake your engine up. :thumbsup:
