1 - 1 of 1 Posts
Hi all. I have an 08 Raptor 700r.
I have just recently replaced the trans and rebuild the top end (new piston, oil seals etc)
Now the bike is all back together I have an issue with the idle. It seems to be running well high and then slows back down give the odd pop every so often. When riding the bike it accelerates fine until I give it about half throttle then seems like it hits a fuel cut (like ATVs do in reverse) it does this in all gears. I have checked valve clearance, air leaks, air filter, cleaned the carb, basically everything I can think of checking and what I have read on other posts on this site dont seem to be helping with this issue. Appreciate the help.
1 - 1 of 1 Posts
