is the bolt the high speed compression and the flathead screw the low speed?if so what is the best settings you guys have for high speed compression as i think i have my low speed sorted.
Are you talking of the shock adjustments..................
There is compression and rebound adjustments..........
Some of the newer aftermarketshocks have high and low speed adjustments........
Ridin High.....
ur weight should only determine your preload, to set your race sag, and ur race sag should be set to your style of riding. then start adjusting your compression/rebound from there.....imo
