1 - 20 of 23 Posts
I have been seeing thing about a high torque starter for the 660 raptor came any one tell me if they make them and if so where I can get one
I've never seen one. The limiting factor may be the starter one-way clutch, not the starter itself.
What is your particular issue that leads to this question?
This thread is 8 years old and Illusive last posted well over a year ago... I suspect you're not gonna get an answer.
2002 660, put a big bore kit on. New jug, piston, head and cover. New starter, starting relay, larger starter cable, oversized battery. I can't get it to start or turn over past the compression stroke. Hitting the starter, it'll turn over until it hits the compression stroke and then stops. Won't push past it. Without plug, it'll crank over fine. I'm at a loss.
Decompression mechanism installed properly?
Measure starting compression. Decomp should keep it at or below 100psi or so.
Jumper your battery to an auto battery - will it turn over now?
It came already attached to the cam, so I'm assuming so. Comparing it to the old one, they look nearly identical and positioned the same. That was my thought as well, but I'm not sure how to test it, or if there's a way to test it.
I'm having the same problem did you figure it out
2002 raptor 660 same exact thing put 719 big bore stroker, new starter, new grizzly battery, will run like a top if I pop start it with my warrior. Turns over beautifully fully charged til compression stroke and will sometimes start if hand turned past compression stroke. Any help
Would be appreciated!
1 - 20 of 23 Posts
