I'm having trouble mounting my new Hiper Tech 3's on my rear tires. I'm thinking I must be doing something whack as I wasn't expecting this to be such a cluster-cuss.
First off. I have the Hiper Tech 3 single bead lock wheels (0980-YHR-SBL) wheel which I believe the 0980 means 9x8. Now that should fit on my ITP Holeshot XC/AT20x11x9 tire right? My understanding is the last number in the tire size should equal the first number of the wheel size, right? In my case 9.
Trouble is I can't get the fricken' bead to seal when I add the air. After screwin' around with it for awhile using tie straps, etc. I finally got it to seal. At least I thought I did anyway. I filled it up to 25 lbs. to get it to seal good with the intention of dropping it way down later. Anyway, with the 25 lbs. in them I happend to stand push on the side wall (don't know why I did this, I was just diggin' 'em I guess) then the fricken bead broke and of course all the air came out. What gives?
Assuming my wheel and tire sizes jive; how exactly do these bead lock rims work? I would greatly appreciate an explanation as to the physics on how these suckas work. Additionally, I'm open to any suggestions/comments as to WTF I'm screwin' up.
Thanks in advance.
Everything sounds right. The HiPer wheels seat just like the rest, although HiPer recommends using WD40 to help seat the bead.
I personally don't mount my own wheels and tires, I take them to a local shop and pay them to do it although I stand there and torque the rings myself.
Thanks for the replies. I'm gonna give it another go. That is, I'm gonna break em down, clean the beads real good and use WD-40.
The UK's fastest Raptor
I had real trouble getting my fronts to seal. I tried WD40 and then soap and water with no luck. In the end I used proper tyre soap and the sealed sraight away. :confused: it was sat in the workshop all along....mocking me :mad:
I thinkg your trying to put a 9 inch tire on an 8 inch wheel.... but i may be wrong
Ok, I got it. I went ahead and tore 'em all apart, cleaned the rims and tire beads again. There must've been a booger or something causing the problem. This time they filled right up. Funny how walking away and coming back the next day made such a difference.
Thanks for y'alls help.
