I've seen some good deals on the hotrods crank/rod on Ebay, not sure if you have any reservations about buying parts from there or not but the prices seem right. The Barker 4mil setup with an off-the-shelf 11:1 Wiseco piston is within 50 bucks of the cost of the hotrods setup with their custom piston. My recommendation would be to use the Barker setup, the rod on that setup is indestructable and you have the same piston choices as someone with a non stroker motor. I run the 6mil in my personal motor and love it but it is 250 more expensive than the 4mil.
