644.00 retail
your cost 560.00
+4mm Hot rod crank
102 big bore piston
10:5 to 1
produces 719cc's :thumbsup:
PM me or e-mail me if your interested
Take care
Kenneth
kbm450 said:
644.00 retail
your cost 560.00
+4mm Hot rod crank
102 big bore piston
10:5 to 1
Take care
Kenneth
Is this a drop in kit or do you have to bore the cylinder?
~Brian
Stock piston is 100mm, this is a 102mm which requires an .080 over bore on the existing sleeve...I guess they could make a "drop in" kit if they included a new cylinder but for this price it sounds as if you must use your old cylinder. You will also have to split the cases to put in the new stroker crank
Right. Maybe go to a higher compression piston with a cam upgrade.
~Brian
2mm overbore job.. Local shops around here bore out cylinders for 70.00.
If you want a complete drop in package pm me, I can also throw in a set of hotcams for a great price.
Take care guys
Ken
