1 - 9 of 9 Posts
I was trying to install a new set of Burgard A-Arms. The fit and finish on the Arms are great. But the balljoints supplied with the arms have a little thicker threaded area and dont want to go in the spindle. Is there a special way to make them work? They are almost in but just not quite. I can see the threaded area come through the other side but not enough to put a nut on it. :(
Most ball joints are tight. You might need to give them a little lovin to get them in. try bracing the spindel and tapping on the back of the joint with a rubber/plastic mallet to get them set.
I tried doing that. I might need to drill to end of the spindle a little. It would not affect the actual seating surface of the balljoint. Do you think that would be OK?
Don't drill anything, it may be you have the wrong joints. some times mistakes happen and you might have the wrong parts, I've had this happen several times with things being for the 660 and not the 700 or yfz parts and not the 700, even my elkas came with the wrong brass spacers when i first got them.
if they are powder coated, you may have to run a wire brush on it, sometimes the finnish gets on the threads. Ive used a shotgun cleaning brush on a drill to do mine.
opps, didnt read close enough....yeh, some use VW bug tie rod ends...they need to be reamed, ...drill press and the correct size bit is what I would use...contavt the manufacturer to make sure....they should have tech support
I drill the small end with a 7/16 drill bit. I barelay had to remove any material. Did not touch the part that actually connected to the balljoints. It seamed to work pretty good. Also I had left 3 messages to the manufacturer about the problem. Thay have not contacted me yet.
1 - 9 of 9 Posts
