i had a mechanic come out to look at my 660 that would idle but when you hit the gas it would bog down and die. he said the cdi was bad. does anyone know if that is possibly true?
He is wrong. If it runs the CDI is working.
Did he check the reverse RPM limiter? (05 has no parking brake limiter, so it can't be that)
The most common issue with Raptors (that matches your symptoms) are dirty carbs, especially pilot jets and passages. What magic did he use to determine the carbs are fine?
